Hi,
What is the best professional multi-format-conversion-software?
I know a few such as Canopus ProCoder 2 and Sorenson SqueezeIt
I'm looking for a program that will convert between different formats including resolution change with customisable options with regards to aspect ratio etc but with best results ie. minimum loss of quality
Thank you in advance
If you are looking for a program that does it all with every type of conversion, it does't exist. Even the pros use a variety of programs. No single program does everything.
This is probably the closest to what you are describing
http://usa.autodesk.com/adsk/servlet/index?id=5562182&siteID=123112
But even then, I would be wary of it doing everything you want.Read my blog here.
If you are looking for stream based transcoding, this product is in wide use for shuttling media through fibers.
http://www.telestream.net/products/flipfactory.htm
http://www.telestream.net/pdfs/datasheets/dat_ff_family_specs.pdf
And this company
http://www.anystream.com/
http://www.anystream.com/images/agility_collateral/anystream_agility_all.pdfRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Suggestions of Professional DVD Authoring Software
By kei_siuip in forum Authoring (DVD)Replies: 25Last Post: 16th Jul 2013, 20:36 -
XViD Conversion: Professional solution?
By plugues in forum Video ConversionReplies: 9Last Post: 7th Sep 2010, 12:16 -
What is the best professional video editing software for PC (2010)?
By exillion in forum EditingReplies: 18Last Post: 15th Jun 2010, 23:04 -
Buying a professional or semi-professional camcorder
By besimky in forum Newbie / General discussionsReplies: 8Last Post: 2nd Mar 2010, 16:21 -
conversion software
By TigerWalkGuy in forum Video ConversionReplies: 3Last Post: 28th Jul 2008, 15:05
